2001 wrx low vacum
raymong
what im trying to explain is that if u see say 12 psi at ur engine (boost gauge on manifold) u will see more if u have it on the wastegate actuator hose due to pressure drop through the intercooler + plumbing (depending where u have the gauge on the actuator line)
  • Replies 63
 raymong said:
will place gauge line to a individual port to see if it makes a difference
how do i tell if the cams are inverted?any markings on the cams themselves?
BINGO ! - IN and EX are clearly marked - you should have seen this upon assembly
they are only marked on the cam gears themselves which i have checked also...
only the driverside (rh) have the same cam gears the only side the inlet is the metal one and the bottom is plastic one
i meant are there actual markings on the cams themselves ..like when i take off the cam cover are there markings on the cams?
No meaning to be rude, but think your in over your head
By the sounds of it, it's time to scope the inj and coil patterns out and go from there
Where abouts are you? if ya local I will come help you out
do i just see if there is power going to the injectors and see if it is within specs of workshop manual specs?
i done the spark test
cyc 2 & 4 has weak spark...hardly sparking compared to cyc 1 & 3 you could actually hear them tick as they spark..
what would you suggest??probe the ecu?its 3 wire plugs im assuming power earth and spark?
3 wire coils
power
earth
and ignition signal for ECU (an earth suppied to trigger power transistor)
Voltage MUST be checked running for inj and these coils
y dont u swap the coils around to different cylinders then see if those cylinders are doin the same thing...which would point u towards the coils being dud...if u swap them around and the same cylinders do it then its the wiring or maybe the ignitor?
 raymong said:
i also double checked the sparks again...took off the driverside leads and started it..and it started so its nothing to do with it..so its running on all 4.
Go back to basics - you posts suggest that your not checking properly, or havent checked the basics
What did you fit that wasnt standard when it came apart? cam sprocket ? etc
Comp test - all the same?
check spark and timing of the spark - use a timing light on an extra HT lead from the coil to check - coil scope patterns
Check fuel - pressure - inj scope paterns
Airflow thru the engine - check for rags in intake pipes etc
i have checked everything...from basic to almost pulling engine out again...
all standard cam sprockets
comp test all above 150psi vary in 10 psi
have check for spark but not timing of the spark
has air flow through engine...no rags in intake pipe
i used the same coil and plug and plugged into each cyclinder. and it was 2 & 4 with the weak spark..
so swaping coils not going to make a difference
mite have to put new set of spark plugs in see if any difference
otherwise mite take to auto electricians
