Check engine light?
luvmaforzzy
http://www.clubsub.org.nz/forum/index.php/topic,67.0.html
Follow the instructions to pull which CEL is popping up. Connect both the small black plugs under your dash near the steering column (with ignition off), turn on ignition and watch the CEL. Long flashes equal 10's, short flashes equal 1's. So 2 long flashes followed by 4 short would be code 24 etc. If you have more than one CEL code it will cycle through all codes before starting again.
This will give you more insight than any of us can over the internet.
You'll need a pen, paper and the ability to count flashing lights.
 luvmaforzzy said:
cool thanks guys ill look it up cause it sounds easy but ill double check on the net to make sure
follow the link mat gave, its easy tells you every thing you need to know
-smurff
 dubbedup']
[quote name='luvmaforzzy said:
bludi light stop coming up lol
it might be stored tho.
Yeah, mine comes on intermittently. Is always after I've been doing lots of engine braking and is always the same code. Can't remember the number but its the one for the Throttle Position Sensor Circuit. Goes away after about 5mins being on but its there when you pull codes.
Pull the code first to see what the problem is/was. Like I said mine is only intermittent so I just clear the ECU of codes after Ive checked it to keep track of everything (I write them down in a book with the date etc).
