Legacy powersteering rack
pl0x
as some of you mite know im having afew issue with my powersteering:
on cold morningt works great for say 3-4 turns then stops and feels heaver
ive brought a power steering pump cause i thought it was stuffed but when i went to pull it off oil squirted out so there was some pressure there so started the car and oil went everywere lol, so i firgure the pump works and didnt replace it.
Ichi ban said this would most likely be the power steering rack
Anyone know what other P/S racks would fit from other subaru models
ive heard legacys have a P/S ecu or something, do any subarus not have this ecu so that p/s just works fulltime
does the power steering light come on at any time?? also have you jacked up the front of the car and tryed turning the steering without load on the steering to see if it still cuts out??
my steering rack kept cutting in and out ended up being a wiring connector on the steering rack with loose wire, the connector is where the steering shaft connects to the steering rack some pressure sensor
yep i would say your rack is shot then and some seals inside damaged bypassing the power steering fluid or pistons in the rack worn
