Wobbly Crank Pulley
I am guessing that like most modern cars the crank pulley is rubber mounted for vibration, so either the rubber in it is shot
Or it done a subaru and the crank pully bolt has come loose and it has worn out the crankshaft,key,keyway :)
 Koom said:
Dunno if they're similar to Subaru ones, but have you taken it off and checked the key for wear? If its got a rubber damper in it that could be deteriorated and about to let go.
Edit: Dammit DRFVDR haha.
bahahahahahah :) quick and the dead lad :)
bah, sounds like lots of effort, oh well will investigate sometime, found a whole heap of little shit wrong, tidying up for little brotehr...grrr why did i offer haha.
hopefully not keyway cause that means toast motor more or less ay
Usually its the key itself that gets toasted not the keyway in the crank. Much easier to replace the key. Not really hard to check, just undo the big nut off the front of it, especially if it's already spat all the belts off.
