big end
wrxboy
 WRXONP said:
It means the tolerance between the piston and bore is too great and the piston is rocking in the bore . . . . It normally happens when cold with forged pistons as forged pistons need quite a large tolerance (compared to a cast piston) to allow for expansion of the piston. In my opinion . Piston slap when cold is not really an issue. Piston slap when hot means she must be pretty worn in the bores .
ohyeah isee.use my car for example.its been rebuilt 10 00ks ago but istill get piston slap on cold start up's.when she warms up the noise goes away like yu said.does that mean that the bores on my car wernt done correctly or is it cause im just running semi forgd pistons.any one know the MAX psi a semi forged piston can take?im sure back in the 90's subaru must have tested to see how mch the semi forgd piston culd take?
Aw ok bro . That sux . Was going to say I could have a look and let you know what I think and discuss ha ha -but its all good . Worst thing it could be is a broken ring land im guessing but could be just worn bore . . Does it smoke ? Use oil ? Its hard to diagnose over the internet
No I've heard of it but haven't tried it? Does it work? Doesn't piston slap stop when it's warm? Because this doesn't. Would it be the drivers side back piston don't they sometimes get starved of fuel because the fuel pumps are to small?
Yeah thats the cylinder that will get lean 1st if it ever goes that way . And yes it works just like a stethoscope . . Use the biggest screw driver you got and you put the end where ever you want to hear it (metal on metal) and put the handle right on your ear . You will be able to put it on various spots on the head and block and you will tell where the noise is coming from when its louder through the handle :) works a treat I bet you will be suprised.. Is the noise louder when cold and quieter when hot ?
