turbosmart boost tee
johnny5
im gonna put a turbo smart bosst tee in to my version 7 i know its been covered before but just a few tips would be cool... do i keep the brass pill in the line or remove it? the stock lines look a little thin what size sillicone hose is recommended? how would you suggest to block the hole on the inlet after i remove it? and do i remove both hoses off the standard solenoid or just 1 if so which 1 there is 1 coming in side on and the 1 at a right angle underneath? and do i unplug the solenoid or just leave it plugged in ? thanks heaps for the tips people
Leave solenoid plugged in to wiring or get cel. Remove vac hoses from solenoid completely. Run hose as short as possible with boost tee in the right direction.. Dont run boost pill or you will get insane spike... Use larger hose (5mm) works best and thats what most controller manufactures recommend
yep.tru and use new vac hoses to.i found heaps of mine were split or leaking from little holes.andddd looks nicer haha
let me know how the turbosmart tee is.the atomic on i used was crap. :)
yea no worries alex will drop you a line thought atomic would have been ok I like to use turbosmart for quality more than anything
 WRXONP said:
Ya cant on the turbosmart ones cos they have 2 little ports on the side . . . You cant hook up to them . . . . Some boost taps are 3 port . . You can plumb them back in . . . . It doesnt really matter any way
sweet az B
Oh yeah sounds good . Would be good to see if it can hold boost good . . I had my old car on dyno with turbosmart boost tee (new style) and each run the boost was quite inconsistent . . Red up online about it and apparently its cos the flow across the ball and spring isnt quite the same each time . . What I red any way lol lol
If ya take em out it will make it spool slower . The theory of the spring is to hold the gate shut as long as possible . . You get better control apparently with them out though . . . Gfb dont run spring and ball at all just straight bleeding all day
yea its one option but that dude is hard to get work done me and him have been trying to get things done for a while jus conflicting schedules so I'm gonna get all the parts on and then hopefully catch him to do it the other option I looked at was E&H motors for the tuning
