Just bought a V1/V2 link and have some questions
1989RS
As the title suggests. Do i need to buy a new map sensor to be able to remove the air flow meter. Can you use the cover from a standard ecu cos it dosent come with one. Im running a preety much bog standard RS the motor has been rebuilt about 7000km ago im thinking of still running standard boost (10psi) but will the internals be able to cope if i put a TD05, bigger injectors etc. Ill post other questions up if i think of them. Cheers
 gotasuby said:
no your car aleady has a map sensor, just un plug afm. yes will bolt into standard case. and a td05 should be fine if fueling and tune is safe
+1
if its a plug in unit, then drive the car to tune shop , let them plug it in an tune it
heard GCP and PBMS have base tunes ready to load in and tweak from there
allow anywhere from $800 - $1500
  • 4 months later...
more specific?
LINK WILL CONTROL FUEL AND IGN AND BOOST
So long as the basics are correct - correct fuel flow and injectors for your set up
Boost on those early links is not so good, and the the lack of tuning "rows" makes precise tuning impossible
