Over heating problems....
Hi Everyone
Im have over heating problem with my Subaru Forester 1997 SF5 Ej20T.
Head gaskets replaced
Radiator replaced
Heat sensor replaced
One side of the radiator is hot.... other side is cold. Also the air con is not working...
Machanics and I cannot work out what the problem is :-\
Any ideas??
Thanks everyone
Hey mate. Based in Bulls... 20 minutes from Palmy... Its been to 3 different machincs in the last 2 weeks and they cant sort it out.
bring it to me and I will fix it
I'm in Wellington - will work out cheaper than wasting more $$ on places that cant fix it
depending on what I find - it may need the dash out to do the heater core
Can do next week for you
Ok i'll keep that in mind. Have burnt through 2 grand in the last 2 weeks getting gaskets.. radiator... clutch etc replaced. Do you have a mobile number? I'll contact you when iv got a bit of coin saved up again if I havent resolved the problem.
Laura :)
Will be as Ichi Ban said, blocked heater core, my BF7 had the same problem when I bought it. You just need to get a couple of T joints and slice them in before the heater core hoses go into the firewall. Ichi Ban could probably explain it to you over the phone if your car won't make it to welly, easy enough job.
Basic job is:
Remove IC
Locate Heater core hoses (2 hoses that run parallel to each other and go through the firewall)
Cut hoses
Slice in T connectors and new section of hose to join the two hoses together
tighten with clamps
put IC back
Hey presto!
all parts available at Repco, can't remember the size of hose/T bits needed though
