1S D55 vs 1S D68 ecu's - 5th injector?
MercuryFree
 MercuryFree said:
Hi all,
Quick question (hopefully) - Does the v3 wrx ra (D68 1S ecu) have a 5th injector? If so, is it even used? Can you use a D68 1S interchangeably with a D55 1S (v3 wrx non-ra)?
Thanks!
only v2 sti ra had a 5th injector, so no, and no it wasn't even used.
1S expects yellow injectors / Orange afm / 8:1 compression, so any 1S will work. i'm not sure about the newer D68 code, it doesn't make much sense.
I thought 5th injector was used on start up or when cold or something?
If you use an ecu that has a 5th injector you need to connect a 5th injector to keep it happy, even if it isn't actally doing anything. Had this issue on my v2 ra, runs fine with injectors upgraded to yellows with no other mods too
 kamineko']
[quote name='MercuryFree said:
Hi all,
Thanks!
Thanks, that's what I thought :)
