Sensor on gc8
RA_Jay
Does any one know what this sensor is for:
its under the manifold, under the ICV on a version 3 sti RA. Under here:
It has two hoses going to it. One from the manifold and one from the PCV valve and on electrical plug. The bit that the hose goes onto has snapped of when I was looking for a boost leak. The plastic looks like it has just deteriorated.
purge control solenoid actually ;D
its part of the carbon canister setup which gets rid of the fuel vapour from the vent for the fuel tank and lets the inlet manifold suck the vapour in and burn it off. Its an emission control thing
if you remove it make sure you plug the hoses properly, one leads to the inlet manifold and will cause a vacuum leak, I've got one here if you'd rather replace it, let me know your address and i'll post it when I get a chance
