1999 RSK possible overboosting
mike wilson
hey guys i own a 1999 RSK which has got a few problems :(
one of the problems it i think it is over boosting :( i have had a wee look around and have found a vacuum leak, not to sure where it is leaking from exactly, but when i block the hose that is T'd onto the waste gate hose, it almost dies and brings itself back up.
i also temporarily installed a after market BOV, i took it for a boost and did not hear any noise what so ever. i then suspected that hose again and clamped it shut then took it for a boost and preformed perfectly.
dont know what to do lol any advise would be gratefull
its going in tomorrow morning to get looked at by the monkeys at armstrong only because the stuffed it up last time and this one is on the house.
one of the mechanics said its normal for a vacuum hose to breath, and i should drive it normally... im pretty sure a vacuum hose should not be able to breath at all lol.
just been reading up the twin turbo operation in the subys and found out the line that is breathing does go to the wasegate control valve
got it back from the mechanic and they said it was only at 10.9psi, and also said its ok to install a SSQ BOV if you block that breathing hose i was talking about earlier. so i did and now its running 15 to 16 psi, is the engine going to last long on that? any ideas how i could get t down if i needed to without removing the new BOV
 mike wilson said:
just reinstalled my factory bov, it kept on stalling the first turbo :(
any ideas on what type of bov i can put on that does not effect this?
Cheers ;D
Thought yo had it running sweet?
 resurrection.inc']
[quote name='mike wilson said:
img]http://img64.imageshack.us/img64/4351/subyprimaryboostmodafte.png[/img]
this is my new set up, im getting 18psi out of my primary turbo. will wind it back soon, am enjoying to to much at the moment lol
[/quote
O u found those pics as well lol
yep lol. have you done this mod to yours?
no aparently its standard on the be in the uk its only the wagon (bh) that u can change to be the same. mine already runs 11/12 or so on primary and 17 on secondary. i think its because i have renewed all my vac hoses with 4 mm. All my old old hoses were so fucked. im either going to sell it or single turbo it next year.
 resurrection.inc said:
no aparently its standard on the be in the uk its only the wagon (bh) that u can change to be the same. mine already runs 11/12 or so on primary and 17 on secondary. i think its because i have renewed all my vac hoses with 4 mm. All my old old hoses were so f***ed. im either going to sell it or single turbo it next year.
Did you get black 4mm Hosing? Im thinking of doing this too. How much did it cost for the hoses and what length did you buy to do everything? TIA
 jaseandjess']
hey ya i used ebay and i think it was sent from hong kong took 7 days and i ordered
6 meter of 4mm (prob need another meter or so)
2 meter of 8mm
i used about a meter of it to do my boost gauge as well so was a lil short with lines running behind intercoller and as you can see it pic i used pretty blue stuff. :)
total cost was $39 nz lol cant buy that over here for that price
ebay trader name is zenaracing
