engine miss
 xsvpwr said:
am I banging my head against a brick wall?
Lol mostly rough idle and missing a bit
But perhaps ask the old owner when it was done and all to get an indication
I personally use copper and m ok to change every 15k
That way can see plugs on a regular basis and pick any issues
Performance wise there is much of a muchness in realistic terms
Some Ppl do say coppers have better ignition
But on most sub 250kw cars I Wud say it won't matter a whole lot if the rest of the systems are in check
But up to u whT u put as cost can be a short term factor as well
to be honest you need to track back when anything was changed. from my experience i found that my car had a rough idle when i had a hks blow valve fitted the same as you a while back, but some appear to be all good?
im my case the cause of my issue was a loose hose clamp and that solved all my problems. mine would miss completely especially in 3rd if i put my foot down. once warmed up on idle it sounded like it had a high lift cam and had a noticeable lope at idle. to me it still sounds like your having a similar issue and i reckon just having a quick once over of the hose clamps on the intake and intercooler etc.
Good Luck :)
