Could be gauge, could be sensor...
pixel-pimp
So Ive noticed this happening more and more lately, where I will be driving, and all of a sudden the water temp gauge will just drop to nothing. Then, it will miraculously fix itself, only to drop again (usually when on boost). Turning the car off will reset this, and it might be fine for the next 2-3 times I drive it, then all of a sudden happens again.
included is a short video link on youtube, youll want to mute it as the bass distorted my mic on my phone...
haha gc, sorry, easiest option take the dash gauges out and check the grounds/ clean with contact cleaner. if not sensor would be the next step, seeming to be common for wrxs around this age..
thats my stock gauge, havent touched anything to do with it. not mechanically smart enough to bother messing with engine things myself haha. will pull the dash off and clean the contacts hoping its that, failing that ill check with the local auto sparky to see if he can get me a new gauge
heres the easiest way you can rule out the wiring which indicates the sensor is faulty
take plug off the single wire coolant temp sensor (single wire temp sensor for gauge and twin wire for ecu)...the single wire sensor earths through the thread like a spark plug does...
so anyway as i was saying..remove wire from sensor and put a split pin in so it gets contact on the wire and earth the split pin..the gauge should rise to maximum (with key on)...if it does this..then the sensor is faulty
