WRX 93 ECU?
soopersubaru
Would like to know more about this ecu.
On the metal outer case is:-U8 22611 AA810
A18-000-RJ2 3218
No AFM fitted.... Oxy sensor is fitted.... Lambda Link Co% meter fitted to vehicle.
I don't know a lot about this ECU stuff! I would like to know if this computer is able to be retuned?
Vehicle is currently running grey injectors, 1 bar boost on Avgas.
What is required to run the vehicle on 98?.... Simply fill the tank and allow the ECU to sort it out?
Thinking of fitting yellow injectors......So im thinking i need to alter the program...How??
There is a 14 pin connector beside the removable square chip.
Below is a picture of the ECU within the metal box.
http://s1203.photobucket.com/albums/bb383/xritagx/?action=view&current=007.jpg
