manifold nipples....
smokn4
chur fallas ,
been trying to figure out where the vaccume nipples that are on top of the early V1/2 wrx's manifold go....
had a look thru the search but couldnt find anything >:(
anyway,
i've got one of them hooked up to my bov and its also tee'd off to my fpr.....
i have another thats going to my boost gauges solinoid but cant remember where the other is supposed to go to ??? ???
can anyone offer some idea's ;D
chur 8)
from memory..
3 in a row
larger one is the BOV
one goes to the ** pressure exchange solenoid -> and out of that into the MAP
& one should be the FPR
then there is one coming out of the throttlebody on an angle, this is the purge line from the fuel vapor canister. pretty sure there is a one-way valve in the line, sitting closer to the canister.
** is usually where people T in for the boost gauge
 sultan said:
How about the brake booster?
thats the larger diameter 'long' nipple on the passenger rear intake manifold runner. that vac line runs to a metal line bolted to the firewall. don't forget the one-way valve that lives in the short connecting hose between the metal line and the brake booster itself.
brake booster metal pipe
connecting hose with valve \
hose to manifold runner
[ engine ] .
| | LONG NIPPLE
aaaand im falling asleep with my eyes open. disregard my ascii art, pictures of actual long nipples are better. (or worse)
