Questions about suspension for my early bg5 legacy
hi there i have a 1993 legacy GT and it feels like a whale (haha best way to describe it) the rear shocks are very soft and the fronts are not far behind and was wondering what i should upgrade to
should i find a pair of bilsteins out of a later gtb bg5 legacy or go with some aftermarket brand shocks and king springs
if u get the bilsteins that fit (im not to sure about models but i know theres 2 types of bilsteins for the rear from different models)
someone will confirm which ones u need
but i tried some bilsteins out in my wrx - DAM they are nice - theyre nice and stiff - but not bouncy stiff like the ver 7 red ones are - theyre very nice to drive and definatly not soft
i would recomend them over the red ones
Bilsteins out of an RSB/GTB BD/BG5 would be your best bet, wagon ones will suit a wagon only and sedan a sedan only (the rear struts are a different length). They help, but are still soft as f*ck if you want to drive fast. So while you are doing it, at least put some stiffer springs in at the same time if you can. Although really your probably better off with swaybars and strut braces.
Be aware that the Bilsteins do wear out, especially the left rear on wagons. So make sure you get an expert to check them before buying.
