Boost gauge wiring
Hikari
Hey guys, I decided to install a boost gauge into my bd5.
It's mechanical and I know that the clear tube is fitted with the T joint at vacuum lines
I want to connect the lighting up with the ignition so that the light is always on. Which wire under the dash is the ignition?
ok back to original question
wire it to the stereo ACC line is best bet here, will only come on with the car etc
saves trying to get to the back of the ignition which is frankly a bit trickier than removing stereo, without making a mess
