Help Code 32
hijacka
Car is a 98 v3 gf8 sti and ive been having some trouble with it since yesterday :'( tried reseting the ecu and flashes code 32, so today went and bought a genuine o2 sensor from armstrong subaru installed and still flashes 32 when i try to reset, doesn't seem to flash any fault codes when in d mode but does flash 32 when in reset mode. car will sometimes run good then sometimes it loses power backfires and stalls like its out of gas and seems to run rough on cold start and idle seems to surge sometimes as well,The downpipe has not got the exhaust temp sensor installed do i need this? any ideas guys im stumped!
  • 6 months later...
Did you figure out what was wrong with your car. Been having the same problem. Have been told its ignition problem. Runs good when it's warmed up now but narrowband says its running lean and smells of petrol. Still has 32 fault code.
desnt sound to actually be a o2 fault - as the o2 isnt used during cold starts or cold temps - it doesnt listen to the o2 untill its warmed up
simptons of a bad o2 is hunting on idle - bad fuel milage and surging under light load
you get same symptoms with o2 unplugged
try unplugging the o2 - it will flash the codes but if it runs better - then its a o2 problem
could be wiring - is it melted?
exhaust temp?? as in for the cat converter? no you dont need that mine ran fine with it disconected
i remember when my ver 3s AFM shat it self - didnt throw the AFM code - but would be hard to start - idle all over the s*** - surge real bad when on load and back fire and stall etc - could be the AFM giving bad signals - could be the dry solder connections problem they seem to get
do you run a pod filter? if so (im not saying its the pod) but if the air intake isnt supported and AFM is just chilling there - the knocks and vibrations it takes screws them
really only guessing here - but im pretty sure if o2 goes out of the parameter it throws the code - car could be running all wack because of AFM and throwing the o2 code ?? only guessing tho
try a afm of a known good running car - someone on here should lend u a afm for a test
