Inconsistent boost
Marky
I have a 97 GTB
It is running just fine, and 90% of the time does a pretty consistent 15psi (ish, the gauge cost me $5) on either primary or both.
Problem is the 10% of the time it doesn't want to, it decides to just run about 8 or 9 psi on primary and then 15 on secondary.
Car has factory downpipes and 3" from Y pipe back, pod filter, and I've already tried de gunking everything with some upper engine cleaner (which for the record is a fricken miracle product).
Is it just the ECU pulling boost back, or would it be the factory BCS sticking closed now & then? Tonight put foot down in third, sat on 9psi for a second or two (I mean quite steady), jumped to 15 for a bit, then VOD time so it's hard to repeat the problem.
Solution is easy (relief valve time) but something in me just likes the idea of leaving it ECU controlled haha
Thought I had cleaned it out (engine clean then CRC up the hoses, seemed to fix it), super intermittently it kept being a munter though. Don't think it was ecu pulling boost back at all purely cause it would sit on 9-10psi and just rando jump up to 15ish halfway through a gear
Went with the solution of removing it from the equation, just running 14psi on primary and secondary via a relief valve now, comes on boost way faster now and much "smoother" I guess, shortens the VOD a bit too which can't be a bad thing. Toyed with the using a hobbs switch or something and a spare solenoid I had in the garage but this way works just as well and I'm too lazy to stuff around any more
Jaseandjess - the factory boost control solenoid is tucked away inside the passenger's guard I think, hose 23 feeds to it and it then vents through hose 10 back the other way. You can trace it from the WG tee-off, up behind the battery and into the wing somewhere.
