Chassis number
Jimbob
the aftermarket gaskets work perfectly fine! you just gotta seam weld the rocker cover to the head after fitting ;D
and erm sorry not much help with the chassis number. are EJ20K / EJ20R all the same in terms of rocker cover gaskets? in which case '97 V3 WRX EJ20K GC8-055980
probably worth taking your old ones into the dealer, theres about 14 different rocker cover gasket versions, they should keep most of them in stock
oh and make sure you replace the rubber washers, they shrink them they're old which is what causes the rocker cover to move around and break the gasket seal
