94 BG5 wagon turbo change
mitchpnz
im sure this has already been asked, but looking through the most relevant post, i cant seem to find the info im after...
without looking at them, is there a standard turbo type that this wagon will have?
all im really wanting to do with mine, is drop the low end turbo, to upgrade it for a bigger one.
what would i currently have, and what is the easiest option for an upgrade? was hoping for the chance of a straight bolt up swap that the ECu will auto-compensate for.
any advise out there peoples?
FIENDHARD
Hey mate, id say you have the vf13 primary and vf14 secondary. Not sure on the ecu upgrade but the vf19 and vf20 out of the bg5 gtb would be your best bet as they are perfect size. But if you want to get big power out of you engine you would be looking at the vf26 an vf27 out of the b4 legacy. And you cant replace the primary without doing the secondary as it will screw with you engine and system. Im not a 100% sure on what i have said but from what i have read and been told id say im close
  • 4 weeks later...
Both your turbo's are the same size they will be vf14 and vf13 running off one internal wastegate, if the engine no: is ej20h the most common mistake people tend to make is that the secondary is bigger what actually happens in that it runs off the one on the passenger side of your legacy and as the rpm picks up and they both drop off then there is a lag which both turbos then spool up in parallel. the only upgrade you can do is as the post above or if you want more power get a bleed valve(manual boost controller) and set the boost up 2 or 3 psi cheap easy between $34 - 99 for average quality
