missing
rawyatt
hey guys. just recently my 1991 rs legacy has developed a miss. it happens in every gear and only when im half throttling or lower. if i floor it the miss goes away but when feathering it the car jiggles/misses pretty bad. codes im getting are just 22 and 24 which comes on then goes off 5mins later and so on. so far i have changed the coils with a mates ones and exactly the same and also have swapped the afm to a recond one but still getting code. and i have been reseting ecu. thanks
  • 3 months later...
well i believe it was a bad coil OR maybe i jumped a tooth as when i removed the cam cover it showed the right hand intake and exhaust cams were off about half/ a tooth. but id check ur coils cause i never found out what my problem was because in the spirit of the moment i decided to rip the whole engine out and build a new motor, sorry cant be any help
