cam position sensors
Pappu1
are the v6 and v7 cam angle sensors the same (goes in under the oil filler cap area)
the units look abt the same just that the plug on the loom is slightly diffewrent
do they all operate on the same pricipal 9hall effect from what i can see)
making them interchangabloe with small loom mod
or do they output different signals???
Hall effect only give on off signals but the length of the signal is Important / I'm not sure about Subaru but normally the signal for cyl 1 is longer than the rest
The sensors operate the same - its wether or not it bolts up and the loom difference
 Stoffa said:
thats the years they changed over, you cant mix and match
Yea man the sensors look identical except slightly different plug
As above I was under the impression that the sensors just used hall effect so didnt matter??
Have a fair few v5/6 sensors and not any v7 ones henc the swap idea
Wud u know what's different in them between the sensors?
 WRXONP said:
why the swap anyway ? car not going?
lol no not that..
just that i have a hored of sensors i collected in my v6 days and while going thru i got thinking of using on v7..
hmm may have to try out..
back the timing by 5degrees and wg pressure first hahah
