Would cam angle sensor affect injectors?
reaperblitz
Found a CEL on the car and it refered to cam angle sensor.
Im assuming that the code is relevant to the same year v3 wrx/sti engine to ecu.
Now the query is, injector 1 pulse is weak. And now, intermittently injector two (front cylinders) on the engine isnt as strong.
Would Sherlock holmes deduction be correct in saying that this could be the problem that affects the injectors?
