boot release
sultan
if the valet lever thing is triggered, and the boot closed, is there any way to open it from inside the boot going in through the rear seats? kind of have no boot lock to open it with the key....
some tard other than myself flicked it and closed it
Id suggest grabbing a flat screwdriver and a flashlight(if its a sedan) the lock usually gets jammed in the wrong place
just flick that ( Get someone to help you from the outside ) and when you do get the person to pull the boot up..
hopefully that helps
I haven't dealt with a subbie with this problem at work ( Mostly Nissan)
should be the same concept though.
