Any one have a working boost gauge I can try? AKL
jpar196
Exactly - if map has a dedicated hose then compare gauge to that
I have allways found that when gauges are near the end of te scale they aren't accurate
Ie running 20 psi on a 20psi gauge only shows 18 - but is fully accurate on lower psi
Must be to do with the spring nearing it's max tension - idk tho
