Rev counter
sultan
The feed comes from the ecu as far as i know, but what feeds that is the question. My car appears to have either a dead altenator or failed voltage reg and Im pondering that the simultaneous failure of the rev counter is related
ok that sounds confusing. are you saying there isn't a sensor or signal from some other component, but the ecu is aware of rpm change some how through the power itself? if so, surely that would be reliant on alternator?
I know that the rev counter I hooked up in the van.came from the top of the dizy. I needed a wee converter to change the wave form as wire tap suggests so my guess is the ecu picks up the signal from tps and electrical diz and converts it. Hopefully you have a diz and not coil on plug.
 Wiretap said:
Whut?
No. The ECU deduces the RPM from the various positional sensors, it then produces the waveform that goes to the instrument cluster... nothing to do with the alternator.
ok...so your first post was basically a confusing way of saying "it gets its feed from the ecu", which i've already stated i am aware of. "various positional sensors" - is what i am trying to find out.
No such thing as an 'electrical dizy'... that's a coilpack, no 'signal' comes from that, the only thing it has in common with a distributor is the fact it has multiple plugleads coming out of it.
The sensors are the cam and crank angle sensor, your engine won't run if either are non-functional. If your alternator and dash gauges are not working check your fuses, the alternator is dependant on the battery lamp on the dash working, if it isn't, it won't charge.
http://en.wikipedia.org/wiki/Ignition_system
What the hiace most likely has is a conventional distributor, the 'signal output wire' will just be a wire connected to the coil negative (in this case I'm guessing the coil is in the distributor), which is traditionally what has been used on non-EFI cars to drive the tacho.
There would be no point to an 'electronic distributor', that's a lot of trouble for a manufacturer to go to instead of using the ECU to control the ignition timing.
