suspension
 pappu said:
will BF5 wagon springs fit on BG wagon struts?
will BF5 wagon struts bolt onto BG wagon?
i have a feeling fronts - yes but unsure
and have no idea on the rears???
Fronts: Yes and yes.
Rears: Yes, but only facelift ones, and You may need to change the tophats.
Bear in mind that BF5s are a lot lighter than BG5s and the arse will sag due to the spring rates.
 pappu said:
ok so fronts defenetly straight fit - thats the struts ay?
do u know if the BF springs are different to v7 springs?
as it fitting them in v7 shocks?
Front springs are the same, Rear springs may be tapered however the taper is different to those used on Ver8-9-10 springs. But yes, front struts will fit unchanged (and the springs should fit anything you throw at them)
V7 front struts only work on gen1 legacys, all others are narrower and it results in horrible positive camber.
