Shorten clutch pedal period - 1996 WRX
I'm wondering how to shorten the period for my clutch pedal. I've tried the bolt under the dash but because my clutch takes so high it starts slipping with hardly any adjustment to this bolt. Is there another way of doing it... on the cheap?
Have you adjusted the shaft that goes to the master cylinder? Need a 6mm spanner and there's two flats on the shaft to rotate it, need to crack the holding nut first then rotate the shaft. Don't go overboard with it though.
I have no idea how to do this. Do you know if there's a guide anywhere??
 insanity007']
Those three sentences are the guide. Its the wee shaft from top of the clutch pedal that goes through the firewall.
 Koom']
I had a look and this makes sense now. It looks like it's got a fork at the end of the shaft with a pin through it that holds onto the clutch pedal. Do I have to take the clutch pedal out to push this back?
