Instaling Syms headers on a BE
666SubSpeed
I want to know what vacuum lines and such that need to be modified / removed to make it run both turbos at once instead of holding back boost in the second turbo. I know a sensor is removed and a resistor is put in its place to fix the CEL but thats about all i have found out. I'm sure members have used them before I am after as much info as I can to help out a mate who is fitting a set.
Syms parallel headers:
Solenoid Box:BE5
Hose No:1 remove/cap (this will leave IACV open)
Hose No:2 remove/cap and cap IC port
Hose No:5 remove/cap (ECV actuator removed)
Hose No:6 remove/cap (ECV actuator removed)
Hose No:8 remove connect hose No:22 from DPS (this will/may stop the DPS CEL)
If CEL persist then leave hose No 22 open to air and cap Hose No:8 .
Remove Supercharger Pressure Relief Valve - SCPRV (Hose No: 22 is connected here) and plug intake port and cap secondary turbo stack
Edited by telemekas
Update
