Right o ( i dont wanan hear about "just leave them in the doors) Ill be doing the doors also.
Will any generic spacers do the job for this? There are some on trademe for $20, or do the spacers need to be some specific size?
I'm also just guessin, without looking, that the spacers need to be there, so that you avoid cutting the metal, but there is still enough space to trim the parcel tray slightly to put the magnet through? *But im guessin cause its dark and I havent even looked on mine yet)*
The plan is, to get 6.5" 4way pioneer fronts (cause iv had them before, and amped, they go fekin fantastic)
Whatever fits in the rear door (also be pioneers)
Pioneer 6X9 rears
All amped via a 4 way amp (the setup on this will depend on how tunable each set is together, obviously ill have to run two sets off one channel)
and pioneer headunit (havent decided on what model)
Yes i like pioneer, only because i cant afford another FOCAL system, o how i miss it :(
Generic spacers will not fit in the doors, no. They will need to have specific subaru hole positions, as they have a triangular shape to them. There are some available from Eds Autos I believe, or go to a car audio store and they can make some out of MDF, based on your existing ones. Will cost you more then a $20 though probably.
Your profile doesn't say where you're from, but if you're in wellington, I have some you can copy.
Im in Temuka, was more asking if the generic 6X9 ones work for the parcel tray?
Also, is there a template i can use to make some for the doors?
