Has anyone Replaced Power steering steel pipes with hose?
hi im doing a flipped v4sti eng conversion into a v2 sti ra, and its nearly done but im having trouble with the powersteering pipes ( my top feed injectors and rails are in the way and the intercooler piping..) any way ive now found out that the v1-2 power steering pipe that goes to the pump is straight, and v3 onwards has a kink allows for the intake pipe to be run on top.
my Question is has anyone swapped the pipe with a hose? i want to cut the pipe where the turbo is located, run a suitable hose then reconnect it with pipe into the pump.
thanks
 funkytown said:
yup you can do that, make sure you use appropriate fittings and hose for the high pressure side - someone like ENZED has to put it together for you, and a reasonable fuel hose is fine for the non presurised side.
cheers, ill look into it damn thing is stressful haha
