GF8 wagon (95)
I ended up buying my partner a Honda Civic Vtec.. so now I own a 95 Impreza wagon turbo & a 96 GTB Leagcy The legacy I will fix and modified the TTies on it but that a different issue.
Curious on opinions about suspension set ups for the GF8, I drove down to Hamilton today it was frigging terrible, sloppy drive I have ever experienced.
I don't want spend to much cash as i want my wagon back on the road.. so, coil overs for the impreza is not an option me, thoughts of a bilstein B12 from a GTB (cheap cheap) have crossed my mind.. wouldn't mind some advice on this one, though. Springs, can anyone suggest a good set of spring, I considered dobi sports.. and sway bar can anyone mention a good sizes.. THANKS I have Titanium F/R Pillowball links from SAS to replace the standard ones and considering the anti lift kit (but heard another VER of WRX does the same thing?) but that could just be stories or not.
Currently done: cambelt, oil leaks checked & fixed (rocket cover & crank seal) new plugs iridium's.. AFM replaced.. there a crappy pod on there which I believe has caused the AFM to go burger again (fix for tomorrow, I'll either, rip it off or anchor it properly and box it)
Working over the body, sanding all the scratches and fixing all the dings, brought most of the panel gear from Becky at Sub bits (shes a gem) I also have a FMIC (which was for my GTB) but it may end up on the GF8.. I held on to the twisted rage exhaust.. exhaust is standard, that may change also.. maybe
have got tein super low springs in mine on standard struts. that with sway bars makes a world of difference.
Not to say Bilsteins would be even better again.. I think you need to keep your top ats if you do that though and put onto the Billies.
Anti lift kit is supposed to be great as well.. Im thinking about doing it also but have not yet to date.
I have the anti lift kit on my legacy .. awesome through and out the corners... I remember the old forum someone mention, another version wrx (ver 5 I think) which does the same thing.. what size sway bar you use?
