03 BP Clock fault
kiwisurf
 kiwisurf said:
Hi.
Is there a known problem with the clock and trip computer on BP Legacy\'s? Non sat nav type.
Just bought one and it works intermittently.
Is it something simple like a dry solder joint or something more serious?
Cheers.
this. very common problem.
After a bit of research - looks like its most commonly under the \'screen\'. You need to remove the screen off the circut board and fix a dry joint. Cant remember which component it usually is sorry.
If your good with these sort of things - it shouldnt be a problem.
Or if you wanna pay someone to do it -
This guy fixes them : $100+gst
http://mitsi-spec.co.nz/legacytrip.htm
