High Pitch Squeal at Low Speeds
It only happens when moving so probably not a belt and doesn\'t happen in reverse. Also only happens between 0-35 km/h and goes away after a few hundred metres. I\'ve recorded what it sounds like from inside the car and posted it in the youtube clip below. (pictures are just me messing round when I first bought my Legacy)
Anyone have an idea what might be causing this?
Cheers!
Definetly a stone stuck inbetween the disc and brake \'cover\'
Had this happen to me recently driving along a freshly laid seal road. HORRIBLE noise.
Have someone jump in and move car forward and back for you - find offending corner.
Jack up car. Take wheel off. use a screw driver or something similar to bend the cover back a bit. You should see a stone fall out.
Common problem on subaru\'s.
