question about the GC8 springs
hi guys, i hav just bought a set of super low dobi springs for my GC8 sedan on trademe. the guy said they were on GC8 hatch but he said they would fit sedan as well. is that right? someone pls let me know if they would fit my sedan or not. cheers
the only difference between sedaa and wagon was the factory springs had a slightly higher rating for the added wagon weight on the rear struts...
not sure on the values but that was what i found out when was looking for spring for my old wagon
fitting wise, they are interchangeable
i guess the wagon springs on rear of ssedan will cause the rear to sit higher and on wagons the sedan springs will sag the rear a bit more than front
 rexpower said:
so the rear springs would not go as low as i want :(
if it was designed for wagon then yes on a sedan it may be ever so slightly higher as the wagon one has bit more weight to compensate for
what area u from?>
