Automatic transmission swap help please
wrs_guy
Hey I\'m replaceing the auto tranny in my 93 hx impreza now I would like some information if I could use a auto tranny out of an ej20 impreza or legacy as my impreza is a ej18 are all the electronics the same or compatible? As I don\'t want to go to the trouble of fitting one and in not working? Any knowledge would be great cheers Ethan.. ???
Stick to the same ago (approx) and you won\'t have any issues, Also there are 2 different sizes of torque converter so if you are using the one that comes with the replacement trans make sure it\'s the same size.
The earlier (98-96) trans are pretty much the same, they made some changes late 96 and then changed again to one with an external filter in 98.
So basically Impreza or legacy will be fine, EJ15 EJ16 EJ18 EJ20 EJ22 EJ25 all use essentially the same trans with small differences in gear ratios, just check the front diff ratio.
