exhaust valve actuator
tez n u
Tried to adjust the exhaust valve to reduce vod....made a difference but car started to overboost and hit boost cut. Now did i loosen it up too much or is there something else goin on? Tighten it back up and no more boost cutt but cars gone slower again :(
...I\'d be a bit sheepish messing with the wastegate adjustment if I were you, but that\'s just me - risk over-speeding your turbo which will eventually cause irreversible turbine damage as it will be pushing it beyond its design rpm/limits. What boost are you getting with it in the normal setting? Any smoke? What are you driving?
Seems weird
ECV should have nothing to do with how much boost it runs unless its not closing properly - but that will only effect primary boost as it\'s stuck halfway switched
how much boost are you actually seeing on both single & twin? to hit the actualy "boost cut" youve got to be running some wicked boost, prob is likely something different altogether
to "adjust" it to the sweet spot, you wind it quite far out so when its idling it sounds monotone, then wind it in (in a hurry as you\'ll burn your hand eventually) to the point where you hear the exhaust note just start to change - the flapper will rattle as it\'s juuuust getting seated - then go a turn or so past that. Means it\'s basically right on the verge of opening so you will find a bit less boost around 3-4k as it pre-spools, but it gives it the longest "reach" it can have via adjustment - means shorter VOD and most gas possible when on secondary so it "should" make more up top
if you want to hold more midrange you wind it closer in, means VOD slightly more pronounced as turbo gets less pre-spool but it holds more flow to the primary between 3-4k
Any idea what level boost got to before it went into fail safe mode? (Boost control via BOV bypass I assume - or is it fuel/ignition cut?)
Link to Twin Turbo information PDF:
https://docs.google.com/file/d/0B1WNPjT7ZI3QYUpic3NpQ0s1NU0/edit?usp=sharing
After adjusting it i took it for a drive and it felt like i hit a brick wall, rev fell to zero and then it started driving normal until i booted it and secondary kicked in and hello brick wall again.....when i put the actuator rod back to normal the brick wall symtom went away :) car doesnt have a boost gauge (just got car couple of days ago)
My understanding is its load based not a specific psi number so it varies a bit, but plenty of folks seeing 20psi plus with no cuts
There should be though haha its 95% the reason these things blow up so much, just let the factory control it bro its sweet oh what\'s that nunga nunga noise it makes now
Cut is an ignition cut as primary bov is pneumatic only and secondary will only bleed when in tt mode
I\'d say get a gauge on it before fiddling they have been known to do some weird shiza (see above re nunga nunga haha)
Ha, yes. Not to be confused with tinka plink tink the sound of your Subaru dieseling its way to an early grave
Or clonka clonka piston slap "nah that\'s just cause they\'re semi forged" cold ej20 either
Its hard to type sounds :(
