Engine failures - Subaru only
Hmm, lost one in my daily GTB - too much boost and it melted piston rings on two pistons.
My old Legacy rally car I did I believe 10 engines. Mind you, some of them it was just little stuff like head gaskets.
Here is some I can remember:
Hydrauliced the first motor when a injector o-ring failed, at idle.
Put a rod out of bed at Slipway doing donuts, due to wastegate hose coming off and freeboosting. Did some mean skids though, so not all bad news!
Overheated at WRC 2010 due to head gasket. Rebuilt this motor twice more afterwards, so the block, rods and forged pistons were strong!
Engine fire from antilag burning through the up-pipe at Rally Wairarapa 2010, blew the turbo with the fire extinguisher and the fire burnt all the wiring loom and the engine overheated killing head gaskets and warping all sorts of bits.
Targa 2011, BEB on the first stage of the whole bloody rally (5 day rally). Only BEB I have ever done...
Targa 2011, 120km/hr into strainer post head on, rolled and caught fire when the sump spilled oil everywhere. Took 5 fire extinguishers to put out... Car and motor written off.
Can\'t remember the rest, but I do remember constantly overheating at MM2010 I think it was, so ended up rebuilding that motor, that was just head gaskets again.
Vivian
