heater - hot or cold only
runrabbit
Any explaination why my wrx heater has lost its ability to go from 20 - 30C in single increments, and now only goes 20-21-HOT in 3 clicks on the control knob?? ???
Does it need a new switch behind the dash, or is it a bigger problem?
searches only come up with heater core issues. I still get cool air and max hot air.
cheers
Haha my old WRX used to do that. Just used to put up with it
Cold up to halfway then you have 1 click of mild warmth then the next click is full hot.
Maybe try getting under the dash and lubing the connections and motors for the air system get them moving a bit more freely.
Took it apart and its a sealed unit and not much you can do with it, unless you are an electrical wizard. The problem could lie anywhere on the unit/circuit board. (my mate had something similar with his oven stove, and apparently it was the capacitors behind the dials)
As I turn the dial I can hear something registering the temp change on the first 3 clicks, then it gets stuck and it just keeps \'clicking\', like a skipping record.
And i also managed to blow one of the heater dash bulbs as well. So another job to add to the list.
might just need a whole new unit. :-\
Try checking the actual motor that moves the flap in the air ducting, attack it with CRC. In fact just attack every motor and connection (electrical or mechanical) with CRC.
When you replace the bulb hit the board behind the knob with CRC just let it dry before powering it up. Might help free things up behind there.
