Installing Boost & Oil Temp Gauges?
LEGACY_BLITZEN
there has to be a million "how to\'s on the net about these ::)
do they have a control unit ? or is it the sweet "defis that dont need one dawg "
are they electrical or mechanical (does the boost gauge have a nipple on the back for a hose or does the hose connect to a separate black box )?
They\'re Electrical, don\'t think it came with a control unit. Think you got to buy them separate?
what exactly do you want help with ?
connecting the sensors to the engine ?
wiring the gauges to a power supply ?
getting the harness through/around the fire wall ?
or how to physically mount the gauges to the dash ?
or all of the above ?
have you opened the boxes to see if they have all the stuff you need in them ?
its a stepper motor gauge . they return to lowest point on power off
All of the above ;) yes I have opened the box, everything is inside. was sealed
before I opened it.
these are the same gauges i have.sorry to say but these are fake.you dont need a control unit to run these.and you can set peak and adjust colour using the button behind each gauge..fairly easy to set up.you only need to power one gauge then daisy chain the others off it.they use daisy chain like genuine defi.oil sensor is simple 2 wire positve nd earth.the boost sensor has 3 wire..red earth lol black positive and white illumination.they buggered up wiring colours..they look the business though.any troubles pm me but u should be fine with the instructions supplied
Yeah fort they were fake, oh well looks the part which is cool with me ;D yeah man doesn\'t look
to hard to wire up, what about the oil gauge?
if they have a little black button on the back thats a give away they are fakes,and dont make the mistake i did and try use a defi controller on these,it wont work.same gauges are on ebay for $30 U.S..oil gauge requires a oil filter sandwich/adaptor then just screw the sensor in supplied.run the power for oil off the boost gauge
