Side Feed (Ver5 Yellows) to Top feed (GDB Pinks)
joshhorn16
Hi All,
I\'m on an absolute tangent to get my car running as sweet as possible. I have had a GDB Sti Intake Injectors and loom sitting in my garage glaring at me every single day so i decided to take the leap with all these other mods i am doing and that is to attach this GDB sti manifold, injectors and coil pack to my Ver 5 Wrx. So far i have nearly completed the coil on plug conversion (high FIVE) but now im stuck as to how to go about the wiring for the injectors as the plugs for the side feed and the plugs for the top feed are different. Please can someone shed some light as to how i should go about wiring the correct plugs to my current loom as i currently dont know the wiring colours for the injectors ?
Josh
 rex-leggy said:
choppie choppie and then solder and heat shrink the other ones on.
easy as
with the injector wiring ive done at least polarity is not an issue
so you are saying aslong the two injector wires are connected to the two old injector wires (any way round) it will work ?
 joshhorn16']
easy as
As far is im aware, im 90% sure.
The ones i did were for link controlled cars so just the 10% uncertain as to weather polarity matters with a standard ecu
I had them confused with magnetic-plunger solenoids instead of solid iron plunger solenoids that induce reversing north and south poles, so always try to pull the plunger inwards irrespective of current direction. yeap i will be running a link setup and yeap polarity doesnt matter
