Knock sensor CEL
Jord
Heading to work the other morning, the CEL came on as I first turned on the car and remained on for approx 1 minute before going out again and staying out for the remainder of the trip, forgot about it until it popped up again yesterday.
Coinciding with the CEL the engine felt very sluggish and a bit jerky, so I figured it would probably be a knock sensor issue retarding the timing and cutting boost. Checked the ecu for codes this morning and sure enough code 22 - knock sensor.
Does the ecu flag a CEL when det is picked or is it normally just when the the sensor is starting to fail?
Can replace the sensor easily enough myself if that\'s the problem...
Car in question 1999 Legacy B4 TT run on BP98 95% of the time.
Cant truly answer that one as I don\'t know too much about the ecu\'s.However same problem happened with me, checked the codes and was 22 as well.
Went one like that for probably a week when the CEL came on and off intermittently, mostly when driving 100km/h.
Changed the knock sensor straight away which fixed the problem. CEL never came on again and no more sluggish or jerkiness.
So I\'d say replace it if it continues happening.
Just my 2cents :)
code 22 is logged when sensor resistance is out of spec - usually from a cracked sensor
22 will not log on OEM ECU with engine knock - ecu will just try to control the knock
replcement is only fix
skilled hands can swap these out in 15min - but i\'d allow yourself 2hrs (a cold engine is much easir to do this job btw)
only I/C need to be removed to access- its very small acess area :(
lol - once you see where the silly sensor is you might drop the F bomb a few times
Getting old one out isnt too bad - but fitting the new one can be tricky
place the mounting bolt into the new sensor and lower it into place - 3/8dr "wobbly" extentions are great to get onto it
oh and make sure you torque the sensor up - 25Nm
