Can fake carbon fibre wrap be peeled off easily?
Hi there,
I am looking at buying a 1998 STI Coupe and the previous owner has put black carbon fibre wrap on the roof and bonnet. Can this be easily removed without damaging the orignal paint underneath?
While i\'m here, what would a 1998 STI 2dr coupe with 140,000kms be roughly worth?
Cheers!
How long its been on may be a factor. I normally heat any decals or anything adhesive I want to remove.
I\'m not sure if thats bad practice or not. Then I use Orange Oil I think its called to remove left over adhesive.
I think it\'s probably been on a while, like maybe a year or two
 wild_south']
Guy next door to my workplace uses a heat gun on a low setting and just peels it off...
I had one of those big plasticy comic looking WRX decals on the flat of my boot, I assume it had been there since stock and it came off ok with a bit of patience and heat.
I think from memory I also used some hot soapy water once I had lifted the first edge to work on the adhesive as you peel.
The main question might be why did he fit it and whats underneath?
ricer?
