suspect ???????? engine failure twin turbo
hey guys im new to forum and i find my 93 bg5 twin turbos motor may have either have
1. a blown no.3 big end bearing
2. a blown head gasket
3. a blown secondary turbo
4. dropped a valve
car starts fine too easy for run bearing (but oil was a bout 2mm down on dip stick) then idles for 2-3 seconds then rough idle and it starts belowing out with white smoke as thick as v8 doing a burnout from exhaust
this all started when i gave my gt a fang(boost) down princess st revs went from 3000rpm jolted to 4600rpm and reds came on (dash lights) motor stalled i restarted and smoke begain to pour out exhaust
i did notice water levels dropping slowly two weeks before it started to do this
ive blown a few primary turbos before never a secondary so i dont know what a secondarys like
havent dropped valve before but thats my stab in dark
i called otago wreckers there stumped (going to sell me new rebuild for cheap :D)
i was in at midway motors and asked chris because i bought car from there and aparently they have fixed a few twin turbos there and he said it could be head gasket but not sure
just want to know if anyone could tell me what it could be a bit of me hopes it could be a easy fix but am prepared to replace motor
cheers james
thanks for you time and any assistance you can offer
it smokes like my r32 skyline doing a skid lol it just thick and white lol im going to start pulling it apart this week ill do a compression test to start with
How quickly did the water levels drop?
Have you checked your coolant for oil? and your oil for coolant?
I blew the turbo seal in my VF10 and i got some white smoke out the back of it, but it wasn't that thick and quickly disappeared into mist if that helps you in any way
