BLE Cooling system help please
monolith
Hey gang,
long time no see.
Vehicle is a 2005 BLE (EZ30), auto, single zone climate control.
I have a quick question: I recently replaced the coolant in my car, and have had a couple of issues since. I\'ve sussed out it probably has some air in the cooling system, and know I need to bleed it out. Problem is, I can\'t seem to find a method of doing this. I\'ve worked on a number of EJs in the past, but never an EZ, hence my question...
Is there a "best" way to bleed the cooling system for the EZ30?
Thanks in advance
Dave :)
Thanks for that - it\'s not overheating, but the temp occasionally sits a little higher than normal, and the passenger\'s side heater is weak. The Internet tells me this is often caused by an airlock in part of the heater core.
I\'ll try popping it up on ramps tonight, and refill the coolant. Cheers :-)
