1st summer nightwars 1st of November friday night
ra555
 sti555 said:
when did you run 10.9 must of missed your car and run cause fastest gc8 was in the high 12s both nightwars that have been this month or is your car the r34 gtr from lastnight
my gc8 did 11.9 nightwars. It played up all night tho. Avi knows
  • Replies 56
  • Created
  • Last Reply
Top Posters In This Topic
 tez n u said:
10.9 at 211km/h ;D
Was that in the finals last night? I had to miss the final battle of the evos! Great job yet again avi! Is that ur best time so far?
Mate ran his blue v4 sti wagon. Factory apart from my old apexi turbo and exhaust and did a 12.8 best with .5xx reaction times which could of been better!
ninja 8, rection times have nothing to do with the overall time. E.g you could sit at the line for 10sec .the timer wont start until you start moving.. Reaction times are only good for races when its first car over finish line.
 ballsrburning said:
hopefully I can go to one of these in couple of months, i\'m looking for low 11\'s secretly want 10\'s but may need 30psi + for that.
I would post pic of engine but I already have a thread so best to link To that http://www.clubsub.org.nz/forum/index.php/topic,20943.210.html
Explains everything I have done on the car which is change basically everything. Your basically getting in the Evo what I want is your Evo stripped or just big turbo built engine?
Well I won\'t match your hp but my car will be a hell of a lot lighter, not enough to get into the 10s though without e85 and huge boost. I run semi slicks which will help buts it\'s just a 2.0l gtx30r turbo. Plus other mods which will help spool etc but not really top end power.
Did you change the Evo 4 engine for newer model that don\'t suffer from crank walk?
I\'ve read a few times that evo 4 is terrible for it and the others not so much. Just going on what I read though never owned one so no personal experience. I guess it all boils down to how you look after it like any car.
 evowrx said:
As for 10\'s on a GT/X 3071 its commonplace on EJ20 overseas.
Cool but probably 2.5 l block on them. After conversation with tez n u and forgeting that i had scat rods rated higher than 600 hp i have decided to reinstate my flexi fuel idea so I can go e85 and push the upper limits of 500 hp hopefully.
