Manual Conversion (95 Legacy GT)
Hey i have just picked up an auto 1995 gt legacy and am new to subies and couldnt find any detailed posts on manual converstion so was wondering...
1) What parts ( big and small) do i need and why?
e.g. Why do i need to swap the ecu to a manual ecu and will this envolve cutting the loom?
will i need to swap over the diff becasue of different ratio's?
2) how compatible are different model ej20ETT gearbox's, will a later model bolt up without any problems and will a WRX box bolt up?
Thanks,
Joseph
You will need -
Gearbox
Rear diff (only if the auto and manual have different diff ratios)
Prop shaft (auto shaft is shorter than a manual)
Gear stick and linkages
Pedal box
Clutch master, slave and line
ECU, not sure on this one. On mine I snipped 1 wire. Earthed told the ECU it was auto, open circuit for manual.
Flywheel (with bolts)
Clutch assembly (with bolts)
Gearbox oil
Others will add if I missed anything.
All gearboxes will bolt up.
  • 1 year later...
