250T Headers
Finally got a vid up on youtube.
250T headers come on some non turbo 2.5 legacys and easily obtainable from a wrecker or pickapart. They are equal length and give a good chunk more power/torque in the low and a noticeable increase in mid/top end back to back with cast stock headers on a stock ecu untuned.
The heatshield may hit the waterpipe that runs across the bottom at the front of your engine but effectively are a straight swap for a standard cast turbo single scroll manifold and use the stock up pipe. Make sure your turbo is mounted well and no weight is sitting on these as they are not as strong as the stock item.
  • 3 weeks later...
Right meaured a set of each wrx vs 250T headers. Just over 35mm ID on the 250T and just over 38mm on the wrx cast ones. May do some back to back logging one day when it has a decent tune on it to see what it does to the top end at given kw.
