2000 b4 runs 1 bar on primary but only .7 on twin mode ? thoughts
lachlan
first step was check codes
got
21 vehicle speed sensor
22 knock sensor
65 differential pressure sensor
reset ecu , test drive 22 comes back
fix knock sensor plug . re test drive , 1 bar primary . .7 bar on twin . very consistent . runs fine other wise . is it possible the differential pressure sensor is backwards ?
seems odd as it has turbo back exhaust from both turbos .
i see the ecu will go to a standard fuel map and pull 5 degrees timing if the knock sensor is mia
any other thoughts ?
good point
yeah surely it would have a spaz if the ecu saw boost from the 2nd turbo first . didnt look that closely .
was odd as it had no intercooler bracket on primary side and there was nothing holding the pipes to the diff pressure sensor
so i think jonny 20det and tama have been in there at some stage
might inspect 2ndary relief valve . as both bovs split the diaphragm on my bg5a.
